Finally got the wheel and tire combo we ordered from tire rack. So the wheels are
Sparco Terra 16x7 and tires are Toyo Opencountry At3 215/70r16.
This set up on the calculator gives me about a half inch lift BUT in reality its maybe about an inch a half. You’ll see the photo further down.
Also the new wheel and tire setup is about 5lbs lighter than OEM. Package weight was 50lbs according to TireRack, So after taking off all the packaging I whipped out the bathroom scale and re-weighed it was roughly 49lbs. (Sorry forgot to take photos of them on the scale) I was in a hurry to get things done ASAP as it was 95degrees fahrenheit in the garage)
Weighed the Oem wheel and tires which are 18x7.5 with 225/50r18 on the 2019 sport and it was about 54lbs.
Here is a side by side comparison:
So I installed the wheels and tires on the left side first to see how much the difference is: You can clearly see the left side is higher than the right side.
Remember I said that this probably gives me about maybe an inch a half more of ground clearance.
No fitment issues after the install, No rubbing, just a tight fit in the front on full turn lock.
Left side close to footwell:
Left side towards headlight:
Before and after photo on the next post
