1 - 20 of 46 Posts
i want some new wheels and im trying to figure out if the 19x8.5 +45 wheels will fit.... dont really know if that offset will work on our cars
Im pretty sure you can go from +55 - +38 on the HRV very similar to the Odyssey. 8.5 should be fine.. I plan on running 18x9 +38 on mine
I've been interested in upgrading my wheels to 19" MDX or RDX wheels. It's nice to see other interested in upgrading too. I thought this forum had mostly older folks. :D I guess it's still too early to expect to see modified HR-V's.
Discussion Starter #10
i was about to buy them... but... since im from Mexico and dollar rate exchange is fuckin expensive right now... ill wait a lil bit more
Here are the 18x9 +38 on my HRV. I think once lowered it should be a nice clean look... 19s might have been nicer looking... hmm..
rims are Work GT5 pretty sure tires are 245/45/18 .. they do poke a little
Do you have pics that show how much your wheels poke out?
I'm thinking of getting 19x8 +35 wheels. I'm wondering if they'll poke out too much.
my rear is flush with my current size, and the front is nearly flush with the arch.
18x8 +44
I've noticed that fronts on Honda's always stick out a bit more than the fronts. I wonder if it's a Honda thing or if all FWD cars have that due to the axles.
I might go 19x8 in the front and 19x8.5 in the rear to fix that. Or just get different offsets.
Can you take a picture for my showing how much the wheels poke out?
I might go 18x8 in the front and 18x8.5 in the rear to fix that. Or just get different offsets.
my wheels don't poke out at all, what makes it poke out is because I run wider tyres LOL
going to be test fitting some 19x9 +42 this week or weekend. ill snap some pictures. i think they are too big but we will see.
I worry more about the weight and suffering gas mileage.
The wheels won't be too big, but the may be too wide. I have 19x8 +35 and they stick out a bit from the fenders. If you're not planning on lowering your HRV, I'd recommend 245/45/19 or 235/45/19 tires. My 245/40/19's almost look shorter than the stock tires.
the tires actually are 245/45/19 which, in the end is taller than stock so the odo will be off. Not sure if i want that. i just want to see what they will look like.
1 - 20 of 46 Posts
