1 - 3 of 3 Posts
while driving my HRV shifts gear into neutral for few seconds and then shifts back again in drive mode. all this happens when the car is running and the gear stick is in drive mode.
also, the dash board displays check engine sign, CTBA alarm comes on
has any one had this problem
I agree with Dammit, you definitely need to visit a mechanic. Or an exorcist, maybe. Given that you're describing issues with the transmission control and a warning light for your braking system, I think you may have an electronics issue to sort out.
When your car shifts into neutral, is it applying the brakes? Because if so, I would hazard a guess that your CTBA sensor is faulty.
1 - 3 of 3 Posts
