41 - 46 of 46 Posts
Honda HRV 2016
Hello, the settings (software) have nothing to do with the brand name (Dasaita, etc.). That software is by Android, usually the PX6. What you describe I had that problem with my car and it was the CAN-BUS (the little control box) but my car didn't have LaneWatch anyway, so that's why I got the black screen. What you need to fix this problem is the correct CAN-BUS and/or the correct wire harness. You should contact the seller and ask for help. My reverse camera didn't work and Dasaita sent me another wire harness to correct the problem and now it works.
Hi, I got the right lanewatch camera working now. It was because of the wire harness.
But, I have another issue, the viewing got flipped between left and right (see picture).
Motor vehicle Automotive design Car Steering wheel Personal luxury car
I tried to check on the camera setting, but has no other options/function to change it. Any idea? Thanks.
Honda HRV 2016
But, I have another issue, the viewing got flipped between left and right (see picture). View attachment 33236
Never mind. I found the setting under "Factory" to flip the camera view. Thanks.
2020 HR-V LX AWD
What brand/model is that? It's huge. These all, well most of the high end ones, use Android software version 10 or 11 (maybe 12 is out but not sure). Anyway, just find your version of software regardless of brand and then search Google and YouTube for help.
Honda HRV 2016
It is "TS10 UIS7862 6GB RAM 128GB 10 inch" head unit. Yeah, it is huge compare to my original 7 inch HU. Like it lots of the size.
The software is already using Android version 11. I'm considering to upgrade to version 12, but I will wait and try first.
I have been spending lots of time to research, re-wiring, upgrading the unit firmware, this and that just to have some of my car's basic features working. And finally, have it just done after almost 2 months. It may still have some minor issue, but acceptable for me.
2020 HR-V LX AWD
I got mine from Dasaita, a 9” with Android version 10 and everything worked out of the box except the rear camera. They sent me a different wire harness and fixed that. My car is an LX though, so it’s a lot simpler.
Honda HRV 2016
The difference is only the lane watch camera, isn't it or there is more?
This new unit also should be plugged and play with some setting adjustment should be ready to use.
I guess, it is because of wrong wire harness was sent in the beginning.
And even the replacement was sent wrong twice (took 7 weeks total in receiving the replacement).
Another thing, it has no manual/instructions and only based on communication with the seller.
In addition, replacing head unit and wiring is new thing for me with no experience at all.
So, I ended up researching and learning a lot such as re-wiring, soldering, and familiar with most of the setting which is great.
After all, I'm satisfied with the unit. The only issue is the 4G simcard signal that is not stable, sometimes full sometimes no signal at all which becomes useless. Instead, I use my phone's hotspot.
41 - 46 of 46 Posts
