See your Aunt Fanny.....
To the OP, just be careful the cure isn't worse than the affliction. Unless it is an easy fix and the plastic just pops back in, both the A pillar and dash plastics may now be used to the way they are inserted or lying, and moving them to the correct position may cause further issues; squeaking and rubbing.
If you have put up with it for 2 years, (or have you just purchased the 2020 vehicle?), then your CDO is not as bad as you thought, and it may be worth it in the long run to tolerate it until you sell it.
