Which wheels do you like the most?
  • Accord Sport (top)
  • Accord Touring (bottom)
1 - 18 of 18 Posts
OEM upgrade wheels used to be a good choice but, IMO, not so much anymore.
They are still way overpriced at the dealer. Common OEM wheels can be found used for a good price though.
OEM wheels used to be US or Japan made and high quality but no longer. Nearly all are made in China these days, very average quality. Nearly all automotive manufacturers these days use low cost wheels made in China.
OEM wheels are heavy cast wheels. Average strength and super heavy, especially if you going to 19's or 20's.
Heavier wheels (rotating mass) is exactly what you don't want on the underpowered HRV with it's small brakes.
In the old days, if you damaged an OEM wheel, just go to the dealer and order one up. Pricey but readily available.
No longer the case, the manufacturers just don't stock older model OEM wheels or any other parts like they used to.
Just my thoughts, I would be researching high quality aftermarket wheels instead.
Most brand name aftermarket wheels are made in China but higher quality for less cost than OEM wheels.
I would recommend light weight 17's or 18's instead of 19's or 20's.
As for your poll, the top wheels look better to me but without the full specs (size, offset, weight and cost), no one can make a qualified recommendation.
Looks are important, but proper fitment is even more important. :)
Reactions: HR-V LX AWD
2020 HR-V LX AWD
Discussion Starter · #4 ·
I forgot to note in my post above, that's not my car. I'm just seeking opinions on looks at this point. I appreciate your input, it's well thought out and makes some good points. However, I did the high dollar high quality light weight aftermarket wheels (BBS) on my high performance premium German (VAG) sedan and didn't find much of a difference to be honest. What I did find was that when it came to replace one that a single could not be bought and if unrepairable, I would have to buy a whole other set of those wheels.
2020 HR-V LX AWD
... but without the full specs (size, offset, weight and cost), no one can make a qualified recommendation
I too would like this information, if anyone can post it please do. All that I know is that they are both OEM 19" wheels.
There was an Accord that, for a while, was parked where I worked. It had the sport wheels. I like the design.
But just like the Civic wheels I mentioned in the thread I created around the time I was considering new wheels/tires, I ended up ruling them out of consideration because they were OEM. As CalgaryHRV mentioned, they're usually not on the lighter side of things.
Because of them being "Sports" or "Performance" versions, they also ended up being bigger in diameter, which in turn, cuts down on the tire sidewall. I wanted to keep as much sidewall as possible to offset the rough ride of the Tanabe lowering springs I put in.
Well the pics are of my car...its FWD..and I just drove 11 hrs and got 32 mpg...car is lowered and I have no issues...but thx for using my car in pics
2020 HR-V LX AWD
Discussion Starter · #10 ·
Hello, both are your car? If so, could you share any technical specifications about the wheels please. Thanks.
2020 HR-V LX AWD
Discussion Starter · #13 ·
I've decided, after seeing them in person, to get the wheels pictured on top. Those are on the 2019-2021 Accord and the ones on the bottom were on the 2016-2018 Accord. I actually like the design of the older wheels better but they're just so dated. I mean, my car back in the 1980's had "five star" wheels on it. So, now the search begins to find a good set of used OEM for the right price.
Also note that the wheels that I posted in the bottom picture as the Touring wheels, those came on the Sport too, so don't get them confused because of the name.
2020 HR-V LX AWD
Discussion Starter · #14 ·
I got the Accord Sport wheels today from a 2021 with the run flat tires. The seller let me test one before I bought them. There are absolutely no fitment problems on my 2020 AWD.
32029
2020 HR-V LX AWD
Discussion Starter · #15 ·
I mounted all four of them today. I forgot to mention above that you need to use the Accord Sport lug nuts with those wheels and they screw onto the HR-V stud with no issues.
2020 HR-V LX AWD
Discussion Starter · #16 ·
First off, I'd like to acknowledge @Samito01 for the picture of his car with these wheels, which was my inspiration. However, after all of my questions going unanswered about fitment and specs I took a chance and dropped $1,200 on a used set of 2021 Accord Sport wheels and tires without knowing if I'd need spacers or to do any modifications. These wheels are on the 2019-2021 Accord Sport but again, these are from a 2021 and you may want to verify that the specs are the same for all of them.
So, here is my post with all specs, fitment and performance notes. My car is a 2020 HR-V AWD and is not lowered or otherwise modified. I have no plans to lower it unless there is a lowered shock/spring package on the market. In short, they fit without any modifications needed and the Accord Sport lug nuts screw right on to the HR-V studs. The wheel locks from the Accord Sport worked on the HR-V too and although both key locks appear similar and had the same part number on them, the key's puzzle was not the same. I did not have to modify the wheels, tires, suspension or body in any way. It just all bolted up perfectly. The wheels are 19x8.5" ET50 (ET is offset) and the tires are 235/40-R19 run flat. Please refer to the pictures posted for all of the technical details. I did not have a way to weigh the them (Accord Sport vs HR-V AWD) but I did not notice any extreme difference between the two when compared as I was mounting them myself.
They are only 0.1" difference in diameter, so the revs and speedometer are nearly unaltered. The tires do not rub inside the fenders or on any of the body panels or suspension. I've driven 200 miles so far, over all kinds of roads and also rail road tracks with no issues at all. I have went over a "speed bump" too and that was not an issue.
Performance wise it's outstanding, the car feels more "planted" on the road. The width of the wheels and tires make it considerably more stable. There is no more wandering/following the road because of the skinny wheels and tires. That blown around the road because of high winds feeling is gone too. It corners better and handles better too. The ride is about the same but I do feel the difference between the stock tires and these, these tires feel firm on the bumps in the road but not harsh. The faster that you're going the less you'll notice that the tires are firm on the bumps. When at usual cruising speed of 50-70 mph, I did not notice the tires being firm on the bumps at all. I did not notice any difference in braking at various speeds.
The pictures speak for themselves as far as how they fit the body and in the fender wells. It no longer has that dinky little car look either, it makes it look a bit larger than the subcompact SUV that really is the HR-V. It looks a lot better in person than these pictures online. The design is opinionated, so I won't get into who likes what, but the main point I'd like to get across is that this is the size of wheels and tires that you want to make the car handle and hold the road better. These make the car handle and hold the road like it was meant to be in the first place. The factory stock size wheels and tires on the HR-V is a downfall, these completely change the characteristics of the car. It feels safer because of the wide wheels and tires and it gets run flat tires too. It's not just about the looks, so choose what brand and design you prefer but these specs (19x8.5" ET50 235/40-R19) are perfect for this car.
I'll update this post with any issues if they come up. The alignment didn't seem to change, the car tracks the same, but I will get a four wheel alignment check just to be sure. If anyone has anything constructive that would help with this experiment, feel free to post. I do have CVT concerns already, not because of these wheels and tires but because the CVT is problematic to begin with already. I will post every 5,000 miles if there are any problems, my car is at 10,700 miles right now.
32030
32031
32032
32033
32034
32035
32036
32038
32039
32040
2020 HR-V LX AWD
Discussion Starter · #18 ·
To the moderator/admin that moved/merged the Accord Sport wheels info thread with this poll thread: people are lazy and are not going to read post #1-15 (which is an opinion poll) or scroll down to post #16 (which was the information thread) to get to the information and specifications post. The wise action to take, if any, would have been to delete the poll thread and leave the information thread intact. So, with that said, anyone who asks me questions because they didn’t take the time to pass over posts #1-15 to get to the information posts beginning in post #16… well, I just won’t help. It’s creating too much unnecessary and extra work for me.
1 - 18 of 18 Posts
