Good afternoon HRV owners. Today I am posting about an on going issue I'm having but only a few days now with my aftermarket tail lights I bought on ebay. These tail lights have a harness already put together that plugs directly into the factory harness for the outer lights and if youd like the inner lights to light up you can use the existing cable they include to splice into a power source. The professional shop that installed them used the License plate lights as they were a solid and strong enough source to power the lights. Pictures included of the before and after. 1 day after installing them my car once i put into reverse had a warning on the screen to put the car in park. once i did that the car shut down. it will not start again and the gear shifter is locked.
I currently have the car with Honda without a diagnosis but they have only determined they will not do any further investigation without putting the factory lights back in. The owner of the shop is putting the lights back in as we speak and will update me once Honda has checked it over again to determine if that was the problem for sure.
My warning to you is this. If you have the same experience or any ideas of why this happened outside of "you installed aftermarket tail lights" or "dont buy ebay junk" then please keep the comments inside. I'm truly trying to help other owners or see if anyone else has had a similar issue.
I reached out to the seller but havent heard back just yet. My understanding is I'm not the first to purchase these lights but I haven't seen any pics or mention of them installed yet so I'm curious to know their outcome and any different wiring that may have had to do.
ALSO, My suspicion is that since the tail lights are changed that something in the computer is detecting a fault or there are no brake lights and its shutting it down. I had a friend with a Toyota who's car was stuck in park because he had a brake light out and until he replaced it he couldnt get it out of park. I guess its for safety but how safe is it to be stranded somewhere trying to put your car in reverse.
Here is the link
http://www.ebay.com/itm/371486391174?_trksid=p2060353.m1438.l2649&ssPageName=STRK:MEBIDX:IT
Here is the link
