I'm looking for some used rims for next winter's snow tires and wondering if the wheels off any other Honda models fit the HRV.
This is one of those debatable topics. Some people say they use the right lug nuts and have no problems. I've read that you shouldn't put the weight of the wheel on the lugs as it puts pressure on them and could also cause vibration. I personally use aluminum hub centric rings as I've read that plastic rings can melt.If the hub bore is bigger, you actually wont need hub centric rings unless you use the wrong lug nuts. OEM nuts have a ball or accorn type seat which centers and holds the wheels in place.
Google, "different types of lug nuts" and you will find all the info you need. Make sure to use the proper lug nuts for whatever wheels you use.
Wheel was just delivered. "New condition" exactly as described, including the "H" logo cap in the center of the wheel. Beautiful packaging, with a black cloth cover stretched across the face of the wheel and closed-cell foam all around the rim. I had a moment of trepidation when I saw a "Black Widow" label on the outside of the box. This is a reputable source on eBay.Not "other" but there is a listing on eBay for brand new (dealer takeoffs) wheels for $130 each (plus shipping).
When you minus size, you drop an inch off the rim diameter, but then replace that with a taller tire, to keep the outside diameter the same. This ensures your odometer, speedometer, and clearance stay the same.But how does the 16 help in the snow? You lose an inch of clearance. I would think the smaller diameter would make the car more likely to hang up in deeper snow.
You save twice with downsizing, cheaper rims plus cheaper tires.I got especially convinced when I discovered that the 16" Nokian tires are $40 less a tire than the 17" ones.
Maybe worth it even though they're nearly twice the price of the steelies.
Did you have to order bulge lugnuts for the wheels?
Thanks again.
Richard
http://www.miata.net/garage/tirecalc.html says....Hi. I recently purchases my 2016 Honda HRV, which comes with P215/55R17 tires, 7.5Jx17 ET55 rims and 5x 114.3 bolt pattern. I have a used set of Mazda 5 2008 rims+wheels, which are P205/50R17 wheels, 6.5Jx17 ET52.5 rims and 5x114.3 bolt pattern. Will they be compatible?
Specification Sidewall Radius Diameter Circumference Revs/Mile Difference
215/55-17 4.7in 13.2in 26.3in 82.7in 767 0.0%
205/50-17 4.0in 12.5in 25.1in 78.8in 804 -4.7%
