1 - 4 of 4 Posts
i've a solution.remove the dome light,in between front and rear seats.splice a wire to the violet colored wire on the light,run your new wire under headliner and to the map lights.now connect this new wire which is a ground wire controlled by door jamb switch,to the ground on the map lights.make sure it is the ground after the switch and not the ground to the frame.after doing so the map lights will come on when doors are opened or can be switched off
I installed some LED bulbs in the interior lights and its much whiter and brighter- just a few bucks and a few minutes.
I installed LASFIT LED bulbs in place of all the interior bulbs, except fot the vanity mirrors, I used some cheap fuse style LED bulbs off ebay. I alsu installed LASFIT LED bulbs for the license plate lights and reverse lights, it looks so good now. I also upgraded the low beam, high beam, and fog lamps with novsight led bulbs, it looks so good now.
1 - 4 of 4 Posts
