According to the UK Owners handbook it is recommended to check the engine oil level at every fill up, and that to do so approximately 3 minutes after switching the engine off - whilst it is still warm.
I check the engine oil level most weekends, normally after stopping off for a coffee. When I returned to the car this weekend the oil level was approximately 1/4 from the top. The car had been sat for around 40 minutes or so on level ground and the temperature was in the high 20C's. This has been the first occasion I have encountered a dip in the oil level since owning the vehicle for over 2 years. The vehicle had its annual service in March, which included an engine oil and filter change as standard.
Earlier today, I checked the engine oil level whilst the engine was cold, and the vehicle had not been started in 24 hours. The engine oil level was right on the maximum level.
I am aware that whilst conducting my initial check with a warm engine some oil will have clung to components or be trapped in various cavities and pipework, however, I am slightly concerned that previously the oil readings were normal when the engine was warm, but this one was out by 1/4 and it has suddenly returned to 100% when the engine was cold. Does this indicate the Honda garage has overfilled the engine oil?
Also, which method of checking the oil level should I use; hot or cold engine?
TIA
TIA
