1 - 4 of 4 Posts
I have the HRV that uses a key not the pushbutton start. When I go to a store I exit the car and lock it with the remote. When I come out of the store the key is still in my pocket I get about 10 feet away from the car and the car makes a clicking sound like the doors are unlocking. But when I try to open the door its still locked , so whats that clicking noise Im hearing?
I would change the battery in the remote 1st to see if it still reacts the same way.
I will try that. This happens when I dont even push the unlock button...I just get near the car and it makes that noise. But I can still unlock the doors with the remote when I push the unlock button, this wierd thing happens BEFORE I push the button/
Your other posts indicate that you have a 2021 HRV Sport.
If your HRV doesn't have keyless start it has the basic remote entry system which means the remote is only transmitting when a button on it is pushed or it is failing in some way.
If you walk up to your HRV WITHOUT your remote is your HRV still clicking?
What about if you use the other remote?
When you hear your HRV clicking try spending some time to figure out where the clicking is coming from.
1 - 4 of 4 Posts
