I purchased a 2016 HRV last June and since day one I have had an issue with the blower on the climate control and after trips to the dealers and the issue still not getting fixed I wanted to put it out there and see if anyone as had the same problem.
When I first start the car after being stood for an amount of time, set the fan to manual, full power, front vents I get what I would expect to be a full power fan of air coming out of the vents however, after 15m or so, the air flow gets weaker (fan speed unchanged).
I recently dropped the glove compartment out and removed the cabin filter to ensure that the fan was still blowing at full speed (which it is) so can confirm its not the blower motor or resistor.
When the issue happens the fan does seem to sound louder (or blocked), and when standing out the vehicle you can hear the intake fan drawing air in from the outside.
Changing any fan setting doesn't seem to sort the issue and with our removing the dash to get to the full air box I am at a loss.
Anyone else out there has and fixed this issue?
