When I'm at a red light, it sounds like an air conditioner compressor is kicking on and off, but the AC isn't on. Is that normal? I have a 2020 HR-V Touring.
Thank you for your quick reply. Is it supposed to do that even if I don't have the AC on?It runs all the time unless you turn it off.
that is not true... It has a temp senor so the unit will not freeze up.. It then goes through a clutch cycling switch and it mounted on the a/c compressor...this will turn the compressor on and off....The only other way the comp. will cycle on and off if you are low on freon...the low pressure switch will do that and that means you have a leak and need a recharge...It runs all the time unless you turn it off.
Curious to hear the results of this one. I noticed the other day that sometimes when cruising for a bit it takes quite a bit more pedal to accelerate. Almost have to push it to the point where kickdown mode is enabled before it will make any adjustment to the throttle.Thank you. I'm calling today about a pause of acceleration while driving yesterday in a local highway, so I'll add this to the list.
the compressor ... cycles on and off too frequently.
Usually a result of excessive refrigerant...
