I suppose one of the USB ports might be plugged in then, I will have to double check.I have the MAX10 and an LX, so I’m sure our wires are different. What model is your car? My car only has one USB port and the adapter went to it, when I plug my phone or a USB thumb drive into that port on the car lower console then it connects to the head unit.
The HDMI out is to connect video screen(s) in the back of the headrest (head restraints). I don’t think that Dasaita sells those though but there are plenty on the market.
I have no experience with amps or subs, so I can’t give any input there but I can tell you that on mine when I fine tuned the equalizer settings then it really made it sound good.
Okay I see. What did you plug #10 into? I think I plugged it into #3 lol and #4 I just have dangling in the back of the dash because I didn't route them to anything.I see now, it’s #4 shown here but since mine is an LX with only one USB port then I only used #3. That #4 wire, I didn’t even plug it in because I knew that I would not need it.
EDIT: I’m mistaken, I didn’t use #3 or #4, I used #10 for the USB
What're you calling "early"? Our July of 2021 build has two USB ports as above. Bought in August, still consider it newI see now that some have two ports, I think the early HR-V and that’s probably what the dual USB (#4) is used for but like I said my car only has a single USB (#3).
Okay thanks for the correction. That’s why I kept saying mine is an LX, it’s only got one USB port.What're you calling "early"? Our July of 2021 build has two USB ports as above. Bought in August, still consider it new
Oh, not sure, I’m using CarPlay but I can tell you that my CarPlay and radio are the same volume. These phones and head units have so many settings sometimes it takes a while to get everything working right. I’ve never even seen Android Auto in person to know anything about it.Another thing I have noticed is the radio is WAY louder than Android Auto. So if I exit android auto and turn on the radio, I have to make sure the head unit is volume 1 before I switch. Also, volume 1 seems very loud, like the volume I'd consider normal listening volume while driving at 30-40mph. Only with the radio though, Android Auto can get quiet.
Perfect timing! I should receive mine today.Great news! I found the Dasaita forum in English and the PDF manual for the MAX10 head unit.
Dasaita Stereo Forum | Dasaita
www.dasaita.com
