261 - 270 of 270 Posts
· Premium Member
First of all, to keep this on topic, I've tried mounting the antenna in different places to get the best reception; I've tried in the dash above the head unit, in the dash above the passenger side vents, on the windshield at bottom and on the windshield at top. It seems that on the top of the windshield is the best place for a good signal and although the antenna seems to be meant to be mounted outside of the car, I didn't want to do that.
Now, about hurricanes, there are several reasons why people stay or leave but it's usually about money. Poor people just don't have the resources to evacuate, some don't have a car and even if they did they wouldn't have the money to get a hotel. Then there is the hours upon hours of 2 million plus people in traffic. Sometimes the elderly can't be moved or don't want to be moved. Lastly, some people are just stubborn and don't evacuate. I have been in all of these situations. It's really a last minute scramble waiting on the path forecast to see if it's heading our way and then be able to book a hotel before they're all sold out.
What I'm after by watching the tv news is after the storm so I can see where we can get supplies and food, sometimes for up to three weeks before things are semi back to normal. I also have a NOAA radio to listen to before and during the storm. The radar app on the phone is my best source of information but that signal is hard to get during the storm. If you've read the other thread on here about fitting a bed in the back, I've noted that was just in case a hotel is not available. What needs to be understood here is that all of these things are last minute viable options. Roads get closed, hotels get fully booked and cell towers get damaged. I'd rather have all of these options than just what is within the FEMA guidelines. Lastly, gasoline has never been a problem, 20 minutes in the car in my yard doesn't take much at all; I've done that to charge the phone before.
· Registered
Hey, finally getting around to fitting my unit, did anyone find a suitable cable to use the existing GPS module and dab antenna? GPS is the grey connector, dab is pink. Also I have a connector left over on the car side, and another on the dasaita side (only had two wires) but the two don't fit together. Anyone able to identify what the cables are for?
· Registered
I'm not too fussed re the GPS, more just tidy wiring, but the dab one for me is more of an issue as I have to install/stick on a new antenna when there is already one fitted from factory!
I may end up going to an car audio place to see what they may have!
· Premium Member
The native navigation on the head unit would require the GPS to be connected and although mine is connected I have never used it because I use Apple Maps on CarPlay. The only significant thing that I can see for the GPS is for the time and location but I do believe that you can set that up manually without the GPS connected.
· Registered
Thanks for the link Dr Toboggan, I've looked through most of the links, however they all seem to be for the AM/FM connector. I've ordered a generic cable and will see if I can cut the plastic casing to fit the Honda connector. If it works then a bit of tape to hold it together and 1 less antenna to install! Need to run the cables for aftermarket dash cam and reversing camera next!
· Registered
Just to follow up, the dab connector I got works,
Fakra Female to SMA male is what you need, but taking off the plastic parts of the fakra side. Bit fiddly but it does fit. I could only get a fakra female to sma female so needed to get a male to male adaptor to make it car antena cable to fakra to sma female to sma male to sma male to dab dongle. Waiting for the GPS cable to see if that fits and will update.
Currently having issues getting an aftermarket Dvr and reversing camera working, bit difficult to get dasaita support due to time difference but I continue to get it working!
