1 - 1 of 1 Posts
31176
31175
I am having issues with the display on the dash area, the one that specifically shows your miles to empty/range, outside temperature, and trip. Occasionally it will flicker on and off, the wrong information and jumble things around while it flickers on a off. It seems to be affect by the outside temp. If it is warm outside the issues doesn't happen as often, but it seem as of a loose connection or wire is loose? If you tap the clear plastic in front of it it will usually come back on. I am trying to rule out mother board, electrical issues, or a loose wire. What would you all recommend. I will try to post a photo of the issue. (Note. As of about 3 months ago, I had to get a new battery.) Almost seemed to spark this issue potentially. It will usually correct itself, but I am afraid after so long it will just stop working.
1 - 1 of 1 Posts
