1 - 6 of 6 Posts
I park in a place with different cars in the driveway
I found this clip recently and I’m trying to at a minimum rule out that it’s come off my HRV.
when you look straight down into the clip it has a number 6 printed on it
I reckon you could check out the HR-V mudguards and then check the front and rear bumper clips.
Followed by the bonnet and the tail gate.
The front bumper will require you to under the car to check on the clips. Make sure the engine is off and the car is in Park or 1st gear for manual. Park brake on too.
Choke the wheels if your driveway is on a gradient.
If all the clips are insitu, you are good.
Clips are used by all cars so it would not be possible to tell if a clip belonged to another car.
I’m 99 percent sure they aren’t front bumper clips because I have removed all of those before and the size does not match . Thanks for the advise - I will try the other things you had mentioned
2017 HR-V. Dynamat-ed. Rockin Sounds.
I'm 65% sure that its definitly from a 1981 Delorean flux capacitor mounting bracket.
1 - 6 of 6 Posts
