1 - 4 of 4 Posts
I have a issue with my engine management lite it came up on my dashboard showing EP and my car kept going into limp mode ivr had the error removed with tha diagnostic machine but it keeps coming back and it's also saying my boot is open when it's not does anybody know what his could be?
What year & mileage? What is 'EP"?
If still under warranty the main dealer should fix (make sure you tell them their previous resets did NOT last).
The tailgate latch may just need a drop or two of oil.
Reactions: SlowFosho
My warranty as and out unfortunately
I went to my car this morning to find the battery had died so would this be the key problems to all the other problems?
Low voltage can really confuse the electronics in modern cars. :oops:
Replace that battery. (Assure that the terminals are clean & tight, as well. You should NOT be able to twist them without loosening. In the USA, many replacement batteries seem to have small terminals, that require shims.)
1 - 4 of 4 Posts
