1 - 4 of 4 Posts
Hi all. I’m looking into buying a little grease gun for a separate project but I’m wondering if anyone has gone around and greased the fitting on their HRV before? I assume there are zerk fitting around the vehicle, but I don’t know if those come in different sizes or if it’s standard size. Also, I see much about psi when searching online; does anyone know if there’s a minimum psi needed to properly grease these fitting? Thanks.
Zero grease fittings on any modern car and truck including the HRV!
Unless you have aftermarket greaseable suspension components installed.
Do a search and download the Honda HRV Service manual.
If you are doing your own repairs and maintenance, the manual will help you greatly.
Edit: A quick google search brings up this link to the 2016-2018 HRV service manual and it is legit:
https://www.reddit.com/r/HRV/comments/akond2
There are minimal changes to the North American HRV, 2016-2022.
IF you develop knocks or clunks, injecting a bit of grease via a needle accessory can help determine the source.
Otherwise, just spray all the rubber boots/covers with silicone on the ball joints/bushings/sway bar links to keep them supple. I do that while draining oil.
1 - 4 of 4 Posts
