1 - 4 of 4 Posts
Hi everyone. So I purchased a set of rear bumper lights to match my smoke taillights.
They fit in the well but the mounting brackets are different than the oem reflector and there are no mounting points.
Wood Electrical wiring Gas Tints and shades Audio equipment
Oem.
Personal protective equipment Font Magenta Carmine Fashion accessory
Can anyone suggest a way to mount these? I was thinking about calking them in but i'm not sure of longevity. Anyway. Thanks for the input. Jim.
not sure how handy you are - BUT can you fabricate some metal tabs( sheetmetal bent into a Z ??) to attach the light to re-use the original Honda screw holes ?
I know they attached to the flimsy plastic bumper cover- so there is not a whole lot of support there anyway.
do the new one even have any screw holes for them -how are they intended to be mounted anyway ?
From what I can tell, the Asian version has an actual bumper that extends all the way to the corners of the car. Those stems lock into slots in the bumper. I found a video on YouTube of the install but it doesn't help because I have nothing there to slot into.
1 - 4 of 4 Posts
