1 - 3 of 3 Posts
I had an aftermarket radio installed in my 2019 HR-V and it's my understanding that the clock in the multi information display is set by the factory radio. So how does one adjust the clock if using an aftermarket radio?
Someone made a suggestion long ago about disconnecting the battery at 12 am or 12 pm.
Actually, it might not work for two reasons....
Disconnecting it is what you want to do BEFORE waiting a bit to reconnect at the time you want. It's the reconnecting that actually starts the clock.
But more importantly... when my HR-V get's power after a disconnect... it starts at 1, not 12 (before getting sync'd to the radio).
If you want to give it a try... disconnect the battery around 11:45 to 11:55, wait and reconnect at 12. If it shows 12 for you, just tighten things back up and you're done.
If it shows 1, like it did for me... try again around 1.
1 - 3 of 3 Posts
