I've been scouring the site thinking obviously someone must've done this, but either my search techniques are wrong or it doesn't exist. Could anyone point me to how to remove the rear trunk interior panel? i'm trying to get to the body of the car from the inside. Thanks
is this the panel on the hatch - the larger panel with the 2 small access doors ( for the tailights ) ?
If so- you start at the top and pry and pop off the one horizontal piece above the window -
Then you can access the 2 D-pillar covers- they will pop off when pulled
that give you access to pop of the lower panel
They overlap- and reinstall is lower first, then 2 D-pillars, then top panel.
If you have any experiene in pulling interior panels off- its the same- you find where those push clips are and you will know how much you need to pull - to pop off etc.
Did someone bump your car from behind? Depending on the dent, I pulled mine out with a suction cup tool, it’s not perfectly straight but the dent is out.
Related Threads
Honda HR-V Forum
91.2K posts
18.9K members
Since 2014
The world's premier Honda HR-V forum discussing Honda’s Hi-Rider revolutionary vehicle.
