You might consider scavenging the head unit out of a 2019 at a junkyard, eBay, FB Marketplace, etc. They aren't terribly difficult to install, and that way you can get an OEM part that shouldn't devalue your car for trade in later.
Link isn't working for me, but there are several threads here on aftermarket radio installs using conversion boxes from Crutchfield. Some neat options out there now that add even more than the new stock radios have if you're willing to tinker
Is it fairly easy to install? Plug and play easy? Would the 2016 cables work with the 2019 unit? And backup/lanewatch cameras fully functional? Thanks.
It should just be plug-n-play since those other systems haven't changed. I only stress "should" because I haven't done this yet but it sounds pretty damn tempting. But that's also why I recommended pulling one from an HR-V instead of buying a third party system - it was designed to work with that equipment.
I had the display set to show the large analog clock as the 'info' screen. Yesterday it stopped showing anything. I have tried various settings to get it back, but no success. If I change the wallpaper, and press preview, I get a mini version of the clock that looks right, but when I press...
Crutchfield has recommended these options to replace my factory head unit in my 2018 Honda HRV. The service agent said this retains all the features (steering wheel controls, passenger side camera, rear camera, USB ports) while adding apple CarPlay.
Has anyone installed any of these products...
Hello every one,
I had HRV 2018 EXL in USA, and I wanted to have the carplay so I can mirror my iphone.
i thought of buying used Radio set of other modern version ( either , but don’t know if it works; any one try it?
or do any one have a suggestion for adding car play as feature with HDMI ...
Hi Guys,
Im from Netherlands Europe and im happy that im one of the first people in my country that drives the Honda HR-V EL 2WD version.
Now i have a problem when i wanted to install multiple APP's from my usb. The install box become grey ? ive have checked the box in the settings security...
