1 - 8 of 8 Posts
Hi
I am having some serious issue with my HRV (Vezel).
Its just 500KM run and car stopped in middle of road. I tried checking everything. Apparent fuses are ok.
Car simply do not start and shows error of "Power system" some pictures attached. Today I put a scanner and it shows 2 codes
P0613 - TCM Processor
P0904 - Gate Select Position circuit
Please help me solve it. Mechanics in my area are not qualified enough to handle this and asking me to open up transmission box.
I found this on google.
P0613 - http://www.autocodes.com/p0613.html Transmission Control Module faulty?
P0904 - Transmission gate select position circuit -malfunction Wiring, poor connection, ECM/PCM/TCM http://www.troublecodes.net/pcodes/p0904/
It sounds like it can be a loose transmission control module (TCM) connector, a bad TCM, or whatever tells the ECU what gear you're on. From what I read, the ECU might not be receiving information from the transmission.
I'm assuming you speak Japanese since you bought it from there. You can probably try a Japanese Vezel forum for better help.
Where are you? The dealer in Japan from whom you bought it should be able to help.
Also, I believe you can change the displays to English ... then sign up on the Honda site and download the Shop Manual ...
1 - 8 of 8 Posts
