Installing apps off an usb device
Up
Up
First of all, there's nothing worthwile in the Honda app package. Why would you want to update any of it?It looks like after recent update from honda (over the air, not at dealership), the trick with renaming apks to HondaAppCenter_A1.apk and installing those doesn't work - application not installed message from android. Had to reset the head unit to factory defaults and avoid installing the updates it picked up to be able to install apks using this trick.
Now, who can tell me what happens if i install them honda updates after i installed the apks? Will the permissions app still work? Has anyone tried that?
By the way, no need to fiddle with USB sticks. Just connect the head unit to wifi, navigate to cmdroid.com, download the apk you need and install it from downloads. You will need to delete the download after you installed it and before downloading another one as android will rename the new download if file with same name exists.
Yes and and no. Yes - the 3 apps i can see there are a definition of useless. No - it looks like the updates app center picks up, contain things like bluetooth stack update (after i removed those by resetting the unit, BT phone calls became a nightmare quality wise).First of all, there's nothing worthwile in the Honda app package. Why would you want to update any of it?
I mean you said you installed an update before your issues with APKs started, that's why I was wondering why you'd want to do something like that. I know you then did a factory reset.Thank you for the tip! No, I haven't open honda app center after i reset the head unit to factory defaults and currently it has two or three updates notifications if i open android taskbar. I believe it will only install those if i get into the appcenter, not before that.
How you connect the head unit to WiFi ???By the way, no need to fiddle with USB sticks. Just connect the head unit to wifi, navigate to cmdroid.com, download the apk you need and install it from downloads. You will need to delete the download after you installed it and before downloading another one as android will rename the new download if file with same name exists.
in settings you have an option to connect to wifi. at least it's there on my Irish 2017 HR-V ES. at work now, so can't say exactly which option, but the picture via the following link shows "wifi networks list" option - try that one.How you connect the head unit to WiFi ???
i have in Ukraine a Canadian HRV 2015
I believe all north American models use the same head unit, which unfortunately doesn't run androidThis wifi thing not available on Canadian models? I don't recall seeing this setting on mine.
I don't get what apps people wanting to install. I can connect Samsung S6 Edge and S7 to my HRV EX through bluetooth and make and receive calls and text messages. Sygic Navigation also works through USB.I believe all north American models use the same head unit, which unfortunately doesn't run android
