21 - 40 of 54 Posts
Right. Did you save/export your permissions in the permissions app and then restored those in the same app after you installed the updates? Or you just reconfigured the permissions in the permissions app manually after installing the updates?
I suspect the issue may be in how the app restored permissions.
First of all, there's nothing worthwile in the Honda app package. Why would you want to update any of it?
Anyway, it looks like you've already installed an update in the Honda app centre. But you can still get custom apps installs working again - you just need to change the "Allowed Installations" using Honda Permissions app as follows:
- change HondaAppCenter_A1.apk "Sig digest sha256" back to PREINSTALL (it will have a random string written there by the update so you need to put PREINSTALL back).
- you also need to re-enter the "Process Permissions" for your custom apps as these will also have been removed by the update
Hope this helps! :)
Can you explain more.
I just bought a new honda, i tried factory resetting but whenever i try to install any app. the install button is greyed out. is there any solution?
Unfortunately I can confirm that with the RC7 version ( 0f.095.01.0021 ), it's not possible to install any application with the naming-hack
Install button is always disabled (grated out).
I'll try to make some additional research in that field.
Ok, I got it working - it is possible to downgrade software to RC6.1 using this package:
https://drive.google.com/file/d/1dLnl6URHkL0AO-u6jDay9d7h58eZYrsA/view?usp=sharing
You just have to download it, put to tue USB stick in root directory (USB has to be formatted as FAT32) and reboot your head unit.
It'll be installed automatically. At the end, just do the factory reset in case if Install button is still gray.
Hello,
I have a Honda HRV since few days ago but can't install any apps.
I have RC7 0F.095.01.1123 build.
I tried your method, I put .zip on the root of usb stick and start head unit with it but it did Nothing.
So I extract the ZIP and put it on the root of usb stick => same result => Nothing.
Can you give more details please ?
Thanks a lot,
Best Regards,
Aureo
Hello,
Thanks a lot,
Best Regards,
Aureo
Was the flash drive formatted to FAT32?
HELP
I tried it on a new 2019 Belgian HRV. Didn't work :(
After selecting the file on the USB, the "install" button is grayed out. Trying to download it directly, but it kept on downloading.
Now after a reset with a 10 seconds push on the power, can't browse, can't update, wrong date and time :(
What is the password after those 10 seconds push on the power or how do I change the date if it is all grayed out in de android settings?
Hi guys, I have a 2016 HR-V, I only bought it from the dealer this past weekend so it’s already been updated to rc9
is it possible to factory reset back to the original fc version so I can install apps again?
and if so how do I perform the factory reset??
i have had all the problems described above, Grey’d put install button, app not installed via Cm droid etc etc
21 - 40 of 54 Posts
