1 - 2 of 2 Posts
2017
Hi everybody I would like to ask if I can replace the side mirror of my LX HRV 2017 model with the side mirror with turn signal?
Thank you so much.
It can be done but a lot of fiddly work. The wiring from the mirror light will have to be threaded through that flex hose between the door and pillar. Then run the wire either to the front side maker wiring under the hood or under dash into the signal wiring. I did this on my Fit years ago. Have thought about adding the arrows behind mirror to mine as have the blinkers already on my 2020.
Trying searching U-Tube. Here is one will give you idea what is involved
1 - 2 of 2 Posts
