1 - 10 of 10 Posts
Hi there,
I'm the new owner of a HRV EX and the backup camera has this weird circular area around it.
Is this supposed to happen?
Thanks!
I see it in both wide view, and the not so wide view. But not "top down".
If this is the way it is, that's fine. I just want to make sure mine isn't broken.
Can anyone confirm if they see the same thing?
I find it curious if they all do this, seems kinda like a sloppy mistake.
Just bought mine this weekend and I see the same thing. I haven't looked at where the camera is actually mounted, but I assume it is just partially obscured so you are seeing what is near the lens.
I would like to know what the distances are on the actual guidelines though.
That's perfectly normal. The backup camera has somewhat of a "fisheye" lens effect, which is most pronounced in the "Wide" view picture that you posted. I normally use the middle of the three choices.
1 - 10 of 10 Posts
