I own a 2016 HR-V EX. Doors respond to the remote fine. Three months ago, (with my foot on the brake) I noticed that the push button start did not turn the car on after a single push. Usually worked on the 2nd or 3rd try.
After a week of that, I disconnected the battery. Car started after a single press of the button. Eventually went back to the initial problem. I repeated this to see if I got the same result and sure enough, same phenomenon.
Three months down, it progressed to not even turning on after a repeated push (+5 or more) of the start button while the key was in my pocket. So I had to put the key up to the button and still press the button a few times.
There is a video of a guy who replaced his keyless access remote module on his Accord.
If this is the solution, the control unit is 300. (PN 38329-T7W-A02, used to be -A01) Afraid what the dealer will charge to install and reprogram if this in fact is the Issue. Anyone else have an issue like this? Wondering if there any other fixes like a fuse replacement that resolved the issue?
I'm beyond warranty at this point at 60K+.
Thanks for your input (in advance).
Dos
Dos
