Ohmygoodness FUNONE,So I have been fooling around on how to lock the doors of my 2016 Honda HR-v and leave the car running while I am not in the car.
(this is so that I can let the car warm up on a cold winter's day)
Step one: get in the car with the key fob put my foot on the brake and start the car.
Step two: exit the car with key fob in hand and close all doors.
(the car will beep letting me know that there is no key present)
Step three: remove the physical key from the key fob and lock the door using the key via the door handle.
All of the doors will now be locked with the car running
( this trick will disable the key fob so you have to use the physical to unlock the door to gain access to the vehicle)
I hope this helps someone.
You, sir, are brilliant. I just bought a black on black 2016 CRV-EXL and I need to be able to lock the doors while the car is running here in Las Vegas, NV. It is INSANE turning a car on and off while running errands in 105-115 degree heat. I just went out and tested your suggestion and it worked perfectly. Now this summer will be bearable.
Thank you, thank you!
