Well, practically every car that I own gets an updated wheel/tire package because I firmly believe wheels/tires to be the most important part of a car- since that's the only part that touches the ground. That said, I try to keep the wheel/tire combo from exceeding the OEM weight. For most cars, I try to go lighter- but when increasing diameter and width, if it's not one of the sports cars- then staying the same weight overall is good. In this case, cost is starting to be a factor since I've bought 3 cars in 2 months (and sold one of them last week too), and multiple cars need new tires, so trying to pull from the wheel stash that's already in the garage.
"Seriously overweight" to me usually means significantly more than a pound per inch of wheel diameter. The 17x9s on my BRZ are 17 pounds, the OE RX-8 wheels going onto the wife's Miata are 17 pounds for a cast 16x7.5, and I'm looking at 11 pounds for 15x8 wheels on my CRX. I got lucky and specced out wheels for my truck that are 24 pounds for a 17x8.5, but those are truck load rated- and even though I went from 30s to 33s on the tire, I lost zero fuel economy. In the case of the HR-V, I think I've been reading around the forum that the stock wheel combo is something like 50-51 pounds? I've had the car less than a week and been pretty busy, so haven't had a chance to start pulling wheels and weighing stuff. To me 50-51 is heavy for a 26.3 inch diameter roller. I think I've seen some all-terrain type 215/70-16s get down into the 27-28 pound range, so with a 22 pound wheel that would come right up to 50 total again. I was hoping to get lighter, but for the HR-V this would probably be ok.
I mostly don't want to lose fuel economy when everything washes out with the taller gearing when doing the math at the pump every tank.
No automatics in this house! I drive only stick, wife drives only stick, son is gonna learn stick when he turns 15 in a few months. Definitely got the 6 speed manual. That's the only way to buy used cars that aren't sports cars... find the stick model and lowball away until you get the deal you want, because the dealership can't get rid of the stick car! Plus the car is much more engaging, cheaper to maintain, easier to pull a-hole shenanigans on the road etc. Long live the manual transmission!
That's the wheel. Hopefully the image tag inserted ok- it's been a while since I've created full posts on forums. I think it'll look ok on the HR-V. Wheel is definitely aluminum. Full spec is 16x7 +40mm offset, 67.1mm hub bore so will definitely clear the factory 64.1mm on the HR-V. Bolt pattern is the correct 5x114.3. If I use this set, I'll grab a set of centering rings like
these so everything is happy around the hub. Then all I have to do is do a quick refinish/paint and they'll look brand new, and mount everything up.
Based on
this thread it looks like 16x7 +40 and 215/70 will fit fine and give maximum wheel well fill at stock ride height with no rub.
I have a set of 15x6 +50 Mazda wheels that
might fit over the brakes (they fit other cars where people swore 15s wouldn't fit). If they fit, I might try a set of 225/75s on to give it that supreme fat tire look.
Anyways, that's why I want to know the OEM weights- just to try and get an idea of where I'm landing with the planned wheel/tire setup in the next month or two, after I put new tires on the Miata, and after I put new tires on the truck. Good rubber is expensive $$$. If nobody knows the numbers, I guess I'll measure and provide to the forum too.
By the way CalgaryHRV, thanks for all your posts around the forum. You were in quite a few of the threads that I went through, and are also the reason why I'm trying to find a cheap set of RSX 16s. For some reason the prices in my area have spiked a good bit in the last few months- I used to see sets for $100-150!
