I have a 2017 AWD model and the same information Dammit referred to is on page 121 of the Owner's Guide and page 383 of the Owner's Manual.
If you own a 2017, Dammit's details supplied are all on page 383 of the owner's manual. As far as I can tell, it's only a list triggered by the maintenance minder, I saw no specific references to mileage intervals.You don't mention which year HRV you have. I have a 2016. In the 2016 Owner's Manual on Page 385 it describes the maintenance service items. The table for Sub-Items is CODE Maintenance Sub Items
1 ● Rotate tires
2 ● Replace air cleaner element*2
● Replace dust and pollen filter*3
● Inspect drive belt
3 ● Replace transmission fluid*4
4 ● Replace spark plugs
● Inspect valve clearance
5 ● Replace engine coolant
6 ● Replace rear differential fluid*
Honda is the only car I have owned that required a differential fluid change, perhaps due to the 4 wheel drive. I have a 2005 Pilot and ignored the recommended 60,000 mile fluid change until I heard noises from the rear when turning. A differential fluid change took care of that and now I change the fluid regularly.I have enjoyed reading & learning about my HR-V. I read this post on changing the rear end differential oil. We are talking about the HR-V, right? I cannot find any mention about this in the owners manual, and no one from Honda ever mentioned it to me. I have heard about replacing the fluid in Honda CVT's every 30,000 miles, but I have never heard of having to replace fluid in ANY differential EVER. Please give me the page number. If there is in fact a need to replace the differential fluid ever, I am going to sell my car. I see no reason for it. My mechanic told me that Honda is getting close to making a maintenance free car, and this would be a step backwards. Please show me...
Yes, brake fluid absorbs moisture and turns black. Eventually it will corrode the caliper bores. I change mine whenever it is no longer clear regardless of time or mileage. Important to flush the entire system and not just the master cylinder reservoir.In case some people are unaware of it. Brake fluid gets replaced every 3 years regardless of milage.
I wouldn't skip any Maintenance Minder items, no matter what a stealership idiot says.My Honda dealer straightened this out for me. Changing the fluid is Recommended, not Required. Since I use my 2018 EX AWD HR-V mostly on paved roads and never in the AWD mode, I see no reason to change the fluid every 30,000 miles. Changing the factory fluid, maybe. As far as I know, the rear differential uses no belts (like the CVT)...I do see a reason to change the CVT fluid because of this periodically though. Something else I wonder about...my User manual only has 150 pages. Some mention higher number of pages...how could that be? I am a retired builder, and use my head for some of these things. I do enjoy learning though. Maintenance free is something all car makers are heading for. I see it in many things
You should have two manuals, an Owner's Guide and an Owner's Manual. The guide is smaller.My Honda dealer straightened this out for me. Changing the fluid is Recommended, not Required. Since I use my 2018 EX AWD HR-V mostly on paved roads and never in the AWD mode, I see no reason to change the fluid every 30,000 miles. Changing the factory fluid, maybe. As far as I know, the rear differential uses no belts (like the CVT)...I do see a reason to change the CVT fluid because of this periodically though. Something else I wonder about...my User manual only has 150 pages. Some mention higher number of pages...how could that be? I am a retired builder, and use my head for some of these things. I do enjoy learning though. Maintenance free is something all car makers are heading for. I see it in many things
The internet is a great thing... Despite what your dealer gave you, you can get PDFs of the various manuals here: https://owners.honda.com/vehicle-information/manualsWhen I bought my HR-V,, the dealer only gave me 2 books…a 150 page owners manual and a much smaller customer information book. It sounds like each dealer is different?
My reliable mechanic says you only replace the rear differential if it needs it. If you use the 4 wheel drive a lot then you might need to. Honda is trying to make money.Guys, This is my 4th new Honda (one of them I drove 350,000 miles), my 4th AWD/4WD car, I have driven over 1 million miles without hitting anyone else, I have built several homes and did every part of them (I only knew 1 other person who could do that), have overhauled many engines and am known as “the person who can fix just about anything” but have never needed to change differential fluid, and needing to that does not make sense to me. I know very well the difference between a differential and a transmission. One of my best friends is a certified Honda mechanic. And every other brand too (including Porsche, Mercedes and BMW..I have seen his certificates). I wrote to Honda America, and they told me that they don’t answer technical questions and to ask my "idiot" dealer. I am here to learn what Honda may not have told us. This brings up 2 questions….does anyone know if the rear differential is always “active”? Something tells me it is not….When I bought my HR-V,, the dealer only gave me 2 books…a 150 page owners manual and a much smaller customer information book. It sounds like each dealer is different?
