1 - 8 of 8 Posts
I doubt that Honda or any aftermarket supplier sells the fabric alone. Instead, you will probably have to buy a replacement driver door trim panel covered in the grey fabric. Find a parts diagram of the inside of the door and you’ll have the part number to order from any dealer.
Discussion Starter #4
Thanks,so far I can't buy fabric alone.The replacement driver door trim panel from Honda costs $250 plus $100 shipping
I would look at this as an opportunity to replace that fabric with vinyl or something more durable. Check with a car upholsterer.
There are aftermarket kits I've seen on this forum to convert to vinyl (coverking?), or pull a junkyard panel (should be enough available by now)
1 - 8 of 8 Posts
