1 - 10 of 10 Posts
Has anyone replaced the fog light bulbs before? Do you need to fully remove that lower cover or can you just remove a section to access the fog light area?
you don't remove anything. take off a few push screws and then pull back the section. google the oem fog light install pdf and there is a section in there with pictures.
Hello, I tried changing the fog lights and could not get the connector to come off. Videos I found online show that you just pull the connector off but ours would not budge. ? Is there a trick to getting the connector off from the back of the bulb? ? Thanks for any insight. ?
There's a tab you press that unhooks from the bulb, then you can pull it off.
Pre-facelift: http://techinfo.honda.com/rjanisis/pubs/OM/AH/AT7A6001OM/enu/AT7A6001OM.PDF
page 401-402
Post facelift:
page 540
1 - 10 of 10 Posts
