1 - 9 of 9 Posts
2017 HR V
At my local dealer, almost at 36k and the battery hold down is rusting and coming apart. They say it's not covered. Sound right to you guys?
Since you are right at mileage warranty cutoff, a “good” dealer would go ahead and fix for free. And should be a cheap fix.
2019 HR-V EX
within a year battery corrosion ate through the black plastic-like covering/paint- i thought it was destroyed- but when I cleaned it in battery corrosion cleaner- then peeled the paint off it was good
then I repainted it with 'Milano Red' paint to match the body- then clear coat- so far so good.
If its that top hold down- its also a 9$ part from Honda I think
if its the tray below - prob a bit more- but not a lot of labor at the end of the day.
2017 HR V
That's it! Can't believe they wouldn't replace it.
I can't believe that they wouldn't replace that. You may want to consider using a high temp clear coat.
I would use plastidip before I used paint. Much more impervious to battery acid and vapors as it’s essentially liquid rubber… Three light coats will do it.
If you're not past the time/mileage on the battery, get the dealer to replace it. Even if you're close, talk to the service manager. This happens because the OEM batteries suck.
I don't mess with paint repair until last recourse.
1 - 9 of 9 Posts
