This is a 2WD 2015 model - I've noticed a few months ago the car has started shaking when going over minor bumps or uneven roads. Initially I thought it was a problem with the rear shocks, ended up replacing them but on inspection they were actually fine and the problem is ongoing. The strange thing is I don't have a noise issue...no clunking and no howling which is typically associated with suspension issues affecting the ball joint, tie rod etc. I decided to do a visual inspection to check for play and couldn't find any. I'm at a loss as to what could be the issue. My only thinking now is perhaps it's the frost struts, that's a bit more difficult to diagnose because the weight of the engine makes it difficult to notice a difference in the front unless it's really obvious. Any tips on what could be the cause? Thanks
