Wow - you get 500 miles to a tank? I'd be lucky to get 350.
500 miles/tank??? I doubt that, unless going downhill all the way. 400 maybe.
Actually, it is the automakers that wanted higher standards.I could see how you could have gotten confused. The Feds here in the US DO regulate and require detergents in all grades of gasoline. However, years ago when they started doing so, their requirement was actually less than what many retailers were doing at the time. This made some retailers cut back to only providing the required amount of detergentcy, to save money. Other retailers kept their standard or increased it. These are the Top Tier brands.
I'm used to that so I checked and fixed the tire pressures. Literally zero miles on the almost 30 psi in the tires. Good thought, thought.If you got an oil change, I suspect they checked your tire pressure. And if they checked it, they likely changed it. I'd do a cold pressure check just to be sure. Dealers and tire stores generally overfill in my experience.
This is the time of the year that they start changing over to a summer blend of gas having a lower RVP(Reid Vapor pressure) here in the US. The summer blend is said to actually offer better MPG, however the difference is very slight and other differences, mainly ambient temperature, make it hard to detect.I was getting just shy of 27 mpg in mixed driving up until about 2 weeks ago. Since I've been working from home for the last couple of years, my drives are almost always the same every week. Very little change from week to week. The only change was an oil change at the dealer. Now my avg mpg has dropped to 25.8. Not sure how an oil change could affect fuel mileage that much but it did. Nothing else has changed including tire pressures.
They do that because ethanol is higher octane. That is literally the only real benefit.elaborate on the ethanol not providing any benefits
Because almost every forced induction guy runs e85...due to its benefits..
or are we referring to this particular engine?
HA the best benefit!They do that because ethanol is higher octane. That is literally the only real benefit.
Also don't need to add gas-line antifreeze in the winter. I wonder how many people still remembered those?They do that because ethanol is higher octane. That is literally the only real benefit.
