Tailgate Lower Trim Panel Removal - How to?
792 Views 11 Replies 5 Participants Last post by  rszappa1
Does anyone know if you must remove the upper, left and right trim before the lower one can be removed? I have a rattling issue that I think originates behind the lower trim. I stuck some foam behind it which works slightly to muffle it but I suspect one of the clips is loose or broken so I'll need to get behind it to investigate.
Vehicle Automotive lighting Hood Automotive tire Car
See less See more
1 - 12 of 12 Posts
2016 HRV right? You should add a signature with year and trim level of your HRV.
It's been a while but if I recall the covers overlap. So it's top piece, side pieces and then bottom section.
I removed it all to make it easier for the window tinting shop to tint the rear window.
Our HRV is a base level HRV that did not have the rear windows tinted.
The covers pop off easily. You should have some of the various clips on hand before you remove anything on a Honda.
Plus you will see how thin and chintzy the rear hatch is. I recommend to spray in some Rust Check or Fluid film inside the rear hatch.
Also make sure the 2 rubber drain plugs/flaps at the bottom are free and clear.
I already mentioned the rear hatch spoiler in your other thread.
See less See more
Reactions: 2
Why the Rust Check?
Yes sorry. 2016
Thanks. A bit unfamiliar with the rubber drain plus you mentioned
Why the Rust Check?
The 1st Gen HRV rear hatch is really thin sheet metal and if you remove the interior covers, the hatch spoiler and the exterior plastic panel above the license plate, you will see that it is just a "skeleton" frame.
There are tons of places for water to enter the rear hatch and it is common for rear hatch to rust on any vehicle.
At the bottom edge of the rear hatch are 2 small rubber drain plugs/flaps at each corner (at each end).
If you examine them closely, they are water drains.
go to youtube....there are a few videos
Reactions: 1
There isn't, at least none that I could find specific to the HRV. If you know of one that would be great
I posted one back a few years ago- look on youtube for Vezel rear camera install etc.
the panels do overlap, so you need to start at the top and take that first then work down and take the sides off THEN the bottom panel - and must install in reverse.
Reactions: 1
about 3:40 into this video
Reactions: 1
Thanks that's helpful. Not super detailed but I'll take it, it's better than nothing. Sucks that the top and sides have to be removed first. That just increases the chances of clips breaking. I'll ensure I get spares before removing
Reactions: 1
Interesting. I have a 2017 and I was planning on dyna-matting the trunk so maybe I can do it then.
That was the one I saw.... It is just a matter of pulling on the panel to release the clips...just go slow..
Reactions: 1
1 - 12 of 12 Posts
