1 - 20 of 82 Posts
Hi guys
The wife and I put a down payment on an EX. Not sure when it will arrive but I was thinking about the keyless entry and push button start.
What if the battery dies in the key fob. How do you get in the car and how can you start it ?
page 443 of the manual:
If the Smart Entry Remote Battery is Weak
If the beeper sounds, the indicator on the ENGINE START/STOP button flashes,
and the engine won’t start.
Start the engine as follows.
1. Touch the center of the ENGINE START/
STOP button with the H logo on the smart
entry remote while the indicator on the
ENGINE START/STOP button is flashing.
The buttons on the smart entry remote
should be facing you.
u The indicator flashes for about 30
seconds.
2. Depress the brake pedal (continuously
variable transmission) or clutch pedal
(manual transmission) and press the
ENGINE START/STOP button within 10
seconds after the beeper sounds and the
indicator stays on.
u If you don’t depress the pedal, the mode
will change to ACCESSORY.
seconds.
indicator stays on.
Thanks for this information. This is my first car with a smart key and was wondering about how the car works when battery flat. Hope this procedure works if and when the battery goes flat. Luckily, I have road side assistance who may help.
Very helpful. Thanks for posting. ;)
seconds.
indicator stays on.
Here's a random question, but here goes... If the door unlocks due to the proximity of the car to the keys, then would it be impossible to lock them in the car? Coming from someone who has locked my keys in the car twice, I hope so.
To lock: Press the door lock button on the front door handle when the vehicle is off. If the remote transmitter is inside the vehicle, the doors will not lock.
Since the transmitter stays in your pocket or purse, you don't have to worry about accidentally leaving your keys in the car. (I've locked my keys in the car a couple of times, too.)
If you have ever found loose change in between or behind the seat...you know things DO fall out of pockets.
But...sounds like that that will not be an issue.
Yes, it is impossible to lock the keys inside the car. Here's a crazy note though. If you start the vehicle, then remove the smart key from the vehicle. (Say a friend exits the vehicle with a bag that has the keys in it) an alarm will sound but the car will remain running. Meaning you can drive off and go wherever you want. But once you've stopped and turned off the car, you can't turn it back on.
1 - 20 of 82 Posts
