And more expensive! SighStill, an automatic is always heaver and larger than a manual transmission
I had the exact same issue with my 2016 HRV today and almost got rearended on I-10 with cars going 80 mph when my car stalled. Towed it an hour to a dealer to be told the transmission repair will be 5k. I have all my maintenance minder done at the dealer, with the most recent appointment being 2 WEEKS ago. My car has 69,000 miles. Needing a new transmission at 70k miles when the car has been maintained by the dealer ever since I got it brand new is absurd.I am seeing a surprising amount of complaints about CVT transmission problems in 2016 Honda HRV and I felt compelled to report my incident. I own a 2016 HRV LE with 100,200 miles. Two weeks ago I had left work and was driving 30 miles per hour on a Main Street when I started losing all power and multiple warning lights (engine, brake system, etc) went off. I was able to turn the car off and on but not engage it in gear. Interestingly, when the tow truck driver arrived, he was able to drive it forward. It was towed to my local Honda Dealership and i was informed it was a shift speed sensor but when connection looked at it checked out fine. Only possible cause was a loose positive battery cable which was then tightened. The car codes were reset. I drove it another 190 miles. Two weeks later I 2 hours away from home when the second incident happened. I had gotten off the freeway and was driving 45 mph when I lost all power. I luckily was able to pull over safely. None of the dashboard lights went off. I was not able to engage the car in either drive or reverse mode. I had it towed 120 miles back to my home and to the same dealership. I was told my transmission was completely out and there are lots of metal shavings in the transmission fluid. They gave me an estimate of $6,500 to fix car. I am currently investigating why they didn’t check the Transmission fluid the first time around when apparently they did a thorough multi point inspection. My husband has a 1993 Honda Civic SI with 220k miles and has not had his transmission broken down. Not sure if there is a faulty transmission but as I’m reading all the complaints on this forum I am now thinking it may be....
Same happened to me at 92000 miles. Metal shavings, same price to fix. I have had several hondas. Never had a problem before.I am seeing a surprising amount of complaints about CVT transmission problems in 2016 Honda HRV and I felt compelled to report my incident. I own a 2016 HRV LE with 100,200 miles. Two weeks ago I had left work and was driving 30 miles per hour on a Main Street when I started losing all power and multiple warning lights (engine, brake system, etc) went off. I was able to turn the car off and on but not engage it in gear. Interestingly, when the tow truck driver arrived, he was able to drive it forward. It was towed to my local Honda Dealership and i was informed it was a shift speed sensor but when connection looked at it checked out fine. Only possible cause was a loose positive battery cable which was then tightened. The car codes were reset. I drove it another 190 miles. Two weeks later I 2 hours away from home when the second incident happened. I had gotten off the freeway and was driving 45 mph when I lost all power. I luckily was able to pull over safely. None of the dashboard lights went off. I was not able to engage the car in either drive or reverse mode. I had it towed 120 miles back to my home and to the same dealership. I was told my transmission was completely out and there are lots of metal shavings in the transmission fluid. They gave me an estimate of $6,500 to fix car. I am currently investigating why they didn’t check the Transmission fluid the first time around when apparently they did a thorough multi point inspection. My husband has a 1993 Honda Civic SI with 220k miles and has not had his transmission broken down. Not sure if there is a faulty transmission but as I’m reading all the complaints on this forum I am now thinking it may be....
Wife had the same problem with her 2016 HRV was driving to work she noticed it was losing power . So she got off from the freeway . Then HRV didn’t want to move anymore Had it tow home. Drained the transmission had tons of metal shaving . We would have the transmission service every 6 months And still went out. Something was telling me from the beginning not to order this HRV WHEN IT FIRST CAME OUT because they were being build in Mexico. I guess I was right . Now to Get it fix Cost half of the it worth that crazy . Called the dealer ship they only have life time warranty on engine they knew what they were doing there .I am seeing a surprising amount of complaints about CVT transmission problems in 2016 Honda HRV and I felt compelled to report my incident. I own a 2016 HRV LE with 100,200 miles. Two weeks ago I had left work and was driving 30 miles per hour on a Main Street when I started losing all power and multiple warning lights (engine, brake system, etc) went off. I was able to turn the car off and on but not engage it in gear. Interestingly, when the tow truck driver arrived, he was able to drive it forward. It was towed to my local Honda Dealership and i was informed it was a shift speed sensor but when connection looked at it checked out fine. Only possible cause was a loose positive battery cable which was then tightened. The car codes were reset. I drove it another 190 miles. Two weeks later I 2 hours away from home when the second incident happened. I had gotten off the freeway and was driving 45 mph when I lost all power. I luckily was able to pull over safely. None of the dashboard lights went off. I was not able to engage the car in either drive or reverse mode. I had it towed 120 miles back to my home and to the same dealership. I was told my transmission was completely out and there are lots of metal shavings in the transmission fluid. They gave me an estimate of $6,500 to fix car. I am currently investigating why they didn’t check the Transmission fluid the first time around when apparently they did a thorough multi point inspection. My husband has a 1993 Honda Civic SI with 220k miles and has not had his transmission broken down. Not sure if there is a faulty transmission but as I’m reading all the complaints on this forum I am now thinking it may be....
Sorry to hear. At what mileage intervals did you have your transmission fluid changed?I guess my number came up. 2017 HRV AWD with 59K. Serviced by Honda for everything recommended. Transmission went out quite suddenly and I came to a stop and that was all she wrote, except for quickly building line of angry drivers behind. Towed to the dealership and got the call it is indeed the transmission. Luckily they will cover costs while putting in the Honda remanufactured transmission. As a added frustration this dealership which is quite large doesn’t have a loaner car available yet. To many stories of sudden cvt failure for me will always be in the back of my mind. Will be trading in no more cvt for me.
Your response is “SO TRUE”!Face facts.............Honda's CVT is weak.
A few weeks ago I was driving to work on the highway and my rpms revved up, all the dashboard lights came on, and I lost acceleration. I had the car towed to the local Honda dealership. They told me that the transmission fluid had released all over the engine. They said they checked the transmission but it was ok. They cleaned the vent tube and replaced the trans fluid. The total cost was $368.
A week and a half later I was once again driving on the highway and the same thing happened but this time they told me that the transmission was shot. Total cost to replace would be $6,500. I contacted Honda corporate and filed a claim just to see if I would get lucky. Corporate contacted me the next week and told me they would not help out at all. I asked why and he told me he didn't have to give me a reason why. He then told me since the high mileage, which is mostly highway miles, and that I never had it serviced at Honda they would not help me out.
I contacted the dealership and they ended up knocking $400 off the labor cost. Final cost to replace was $6,156.58
Maybe it was my fault since I never changed the transmission fluid but the MM never displayed the code.
I also used the paddle shifters on a regular basis to accelerate to pass vehicles. I'm not sure whether this affects the transmission but if it does then why to they put them on cars to begin with?
Needless to say I am done with Hondas. I have purchased 3 brand new Hondas over a 30 year period and corporate new that but still did not want to help out.
"Check your CVT fill plug and vent every time you fill up with fuel."
I never knew about the vent until my trans fluid released itself all over the engine. I figured after the dealership refilled the fluid, the transmission would have lasted longer than a week and a half.
Your comments are well taken and with some very good advice. I hope that other people can learn from my hard learned lesson of not maintaining my CVT trans. At least I now have a 36,0000 mile warranty on the new transmission but I will now do a better job of maintaining it.Sorry if my previous post was a bit blunt.
There are many folks that have had a 199x Honda Civic, manual trans, zero options. Drove it for 200 000miles, no problems, replaced the battery once and opened it's hood twice in 20 years.
I don't think any modern vehicle, including Honda's, will duplicate nor tolerate that.
Not any CVT trans, not any direct injected engine, not any turbo engine, not the electronics.
I also think that automatic transmission technology is in transition. 9 & 10 speed traditional automatic transmissions, CVT's, DCT's and likely a few more.
Until these transmissions have been around for many more years, they are going to be problematic.
I suspect some of these technologies may even be abandoned in the future.
We have a Dodge Cummins diesel. In the old days a Cummins diesel would run for 500 000miles with little issue.
No modern Cummins diesel will do that.
At least the HRV 1.8L port injected engine, is totally solid and reliable.
This is not necessarily the case with other Honda engines and with other manufacturer engines.
Ouch! At that price, I would've sold it to a "we buy junk cars" yard for $500 and bought something else.I contacted the dealership and they ended up knocking $400 off the labor cost. Final cost to replace was $6,156.58
A single good salesman at the store I worked at can sell 20 cars a month. A great salesman can sell double that. Automakers want customers who will lease or buy a new car every 2-3 years. You bought 3 cars over 30 years. Suffice it to say, you're not their idea of a good customer so that's why they aren't willing to help you.Needless to say I am done with Hondas. I have purchased 3 brand new Hondas over a 30 year period and corporate new that but still did not want to help out.
I'd go further and say that CVTs don't belong in road-going vehicles, except e-CVTs in hybrids. And e-CVTs are not true CVTs to begin with.Face facts.............Honda's CVT is weak.
