Unknown Device Fell Down
912 Views 6 Replies 6 Participants Last post by  iggination
Does anyone know where do these wires go underneath the driver side of the 2023 HR-V EXL? It fell down and was held on by some sort of square tape.
Automotive tire Motor vehicle Trunk Automotive exterior Auto part
See less See more
Status
Not open for further replies.
1 - 7 of 7 Posts
It looks like an aftermarket GPS tracking device. "This side up" is the giveaway. If you don't know what it is and don't use it I would follow the wires up and remove it. Someone is watching you and keeping tabs on you for sure. Google the numbers on the white sticker.
Tracking Device Found in Customer's Car! - YouTube
Reactions: 3
^^ Exactly...
It's likely a financed or leased vehicle that is being tracked. Very common these days.
Reactions: 2
Before you remove it Contact your bank or if you lease it call them. If you remove it you might be breaking the contract you have with them. If they are responsible for it ask them why and then check your local, state, or federal laws on using such a device. The unit will also cause battery drain and HR-V's are not known to a long-lasting battery if there is a consent drain on them.
Reactions: 2
Good accurate advice from all contributors to this thread.
Reactions: 2
That is an Arrow M Connected Holdings tracking device. It's an LTE network-connected(cell tower) + GPS tracking device. These are not your typical GPS devices that use only satellites. These use cellphone tower reception to provide pin-point positioning accuracy 24/7. They usually have a built-in capacitor and ping location in low power mode while the car is off. It's fused and should be connected to your OBD port. This all means it pulls power from the OBD/battery only while the car is on. There's zero chance for it to drain your battery.
As an experiences car salesperson, this device is seen in ONLY two occasions:
1. Used by insurance agencies from the consent of insured in order to attain lower premiums.
2. Used by dealers who provide risky private loans, or offer loans through non-typical private banks. These are the kind of loans where your car gets towed after being late on 1 car payment. In this scenario, the dealer that sold you the car is the party who installed this device on behalf of the financial institution that they do business with for you to get the loan.
If this device was installed due to insurance- you would know.
if this device was installed due to your loan- it would be documented, and only know if you actually read your loan agreement.
If none of the above are true, someone else is keeping tabs on you 24 hours a day!!
See less See more
Reactions: 3
1 - 7 of 7 Posts
Status
