Has anyone had any water accumulation in the rear hatch door? When opening and closing the hatch we can hear water sloshing around. We pulled one of the panel clips loose and were able to drain off most of the water any ideas out there?
Just noticed your ad,its the hose in the hatch for your rear washer fluid,hose --its not connected.Has anyone had any water accumulation in the rear hatch door? When opening and closing the hatch we can hear water sloshing around. We pulled one of the panel clips loose and were able to drain off most of the water any ideas out there?
Our dealership told us that the water sloshing in our rear hatch door was caused by a seam seal that failed. Terribly disappointed in the way it was handled. Hopefully there will a recall based on manufacturer defect and we will be recompensated.Has anyone had any water accumulation in the rear hatch door? When opening and closing the hatch we can hear water sloshing around. We pulled one of the panel clips loose and were able to drain off most of the water any ideas out there?
Yes, my HRV has had this problem for 2 years now. Took it in to the dealership many times. They changed the tailgate ruber seal, they adjusted the hatch, changed the wiper motor and re-sealed the screws holding the licence plate, still water comes in when there is a heavy rain. Just yesterday, the dealership now thinks it's the rear spoiler that is not properly sealed around the top of the hatch. ??? Quite discouraged about all of theses repairs that don't solve the problem.Has anyone had any water accumulation in the rear hatch door? When opening and closing the hatch we can hear water sloshing around. We pulled one of the panel clips loose and were able to drain off most of the water any ideas out there?
Ok tell them to check the deal on your attenna on rhe roof,water gets under many,if the car is totally dry after washing you will see still water coming our from the attenna on the roofYes, my HRV has had this problem for 2 years now. Took it in to the dealership many times. They changed the tailgate ruber seal, they adjusted the hatch, changed the wiper motor and re-sealed the screws holding the licence plate, still water comes in when there is a heavy rain. Just yesterday, the dealership now thinks it's the rear spoiler that is not properly sealed around the top of the hatch. ??? Quite discouraged about all of theses repairs that don't solve the problem.
Seal sorryOk tell them to check the deal on your attenna on rhe roof,water gets under many,if the car is totally dry after washing you will see still water coming our from the attenna on the roof
I just had this happen today for the first time on my 2016 HR-V! Is there no recall for this?Has anyone had any water accumulation in the rear hatch door? When opening and closing the hatch we can hear water sloshing around. We pulled one of the panel clips loose and were able to drain off most of the water any ideas out there?
Hi, just picked up my car after holidays.. it been sitting for a week , sounds like it has a lake slooshing around in the tailgate. Did hear water previously but this is a whole new level. Did you find this I covered by warranty? I'ts a 2016 model.Has anyone had any water accumulation in the rear hatch door? When opening and closing the hatch we can hear water sloshing around. We pulled one of the panel clips loose and were able to drain off most of the water any ideas out there?
yes there is one nut that is hard to get to to remove the rear tail lamp. If you can get it off, just drill a small hole at the bottom of the lamp and the problem will go away. check the thread on water in tail lampI took mine to the dealer and was told it's not covered under my warranty because I was outside my warranty period. The told me my driver side tail light needed silicone to be sealed.. Wanted to charged me $300 to do it. I said no. I'd do it. Problem is that one of the bolts is very hard to get to. I did discover that if you unscrew the rubber stoppers at the bottom of the tailgate, the water will drain out.
I'm not seeing water in the tail light. It's inside the tailgate and drains out when I unscrew the rubber bumpers at the bottom of the tailgate.
