1 - 3 of 3 Posts
Hello 👋
My rear hatch is leaking.
When pouring rainy day.
My car is leaking. Not the spare tire area.
Tire Wheel Bicycle tire Motor vehicle Automotive tire
Comfort Automotive design Textile Beige Personal luxury car
Like this.....
Every time I checked after the rain.
I found a leak in my hatch...
And I directly headed to YouTube to find some info on this situation.
So I searched for Honda water leaking.
And I found this video.
This video is not for Honda HR-V.
But it helps anyway.
In this video, honda fit owners said that outside of the welding area is a problem.
So fit owners apply some waterproof silicone to prevent some water leaks.
So I bought some injectors to find where I can find some leaking spots to fix.
Tire Wheel Automotive tire Automotive lighting Hood
After I checked some welding spots.
I found something.
Automotive design Motor vehicle Automotive exterior Fender Freezing
Can you see this???
The little crack in the rear hatch.
So I injected water into that crack.
Yeah! I found a leaking spot!
As you can see the square sponge is already soggy with water.
Hand Automotive lighting Hood Window Motor vehicle
This water makes a square sponge wet.
That result makes my interior trim piece wet.
So I went to the Honda service center.
And explain where my car leaks.
If I rewelding that part it will cost over 1500 dollars.
So I don't want to rewelding I just want to apply silicones.
Honda service center said okay I will.
Then the final result.
Hood Automotive tire Automotive lighting Automotive design Motor vehicle
Window Hood Automotive design Automotive exterior Automotive tire
Good result.
I want to make sure of this leak.
So I did my first auto wash.
But nothing is happening so far.
And my country is rainy season.
It's still dry as beef jerky. 😏
Good move.
You co need to check the other side, too.
I have found that Permatex Flowable Windshield Sealant works great! It flows INTO the crack, not just the surface, so it seals better.
On your white car, it will dry a bit yellow, so don't use too much. (Or mask the edges)
Reactions: John35g
Hello 👋
Like this.....
I found something.
Can you see this???
Good result.
Good move.
Oh!!! Wow, thanks!!! If my silicones peeled off I have to try your suggestion silicone! Thank you 🤭
1 - 3 of 3 Posts
