1 - 6 of 6 Posts
Hi,
I have waxed my HRV each year since I bought it and have found
that getting wax on the black trim around the wheel wells and the rocker
panels is a pain in the a&* to remove. This year I decide to use painters tape
to mask off the black trim. Took about 10 minutes to mask off trim, made life
much easier :) When I got wax on the trim I used Mothers Black Trim Restoration
to clean it up but it took about 3 coats to completely remove the excess wax. I found
masking it off makes it easier. Let me know what you think.
That product is made to restore the black plastic trim back to it's original color. Here is a secret....a can of WD-40 or a jar of peanut butter works well too...try it
Rather than that, use a final wax/ protectant /sealer that doesn’t make white marks on the trim. There are many… Meguires new hybrid ceramic spray wax is one.
2019 HR-V EX
Nice outcome! A lot of work though.
There are several hybrid ceramics available that don't whiten the unpainted plastic. The Meguires hybrid is good, as is Turtle Wax Spray N Shine. Even a Wax-As-You-Dry product will not whiten plastic (tho' it needs to be done a LOT more often than the ceramic hybrids).
Turtle Wax ICE was one of the first non-whitening synthetic waxes. But the ceramic hybrids are better.
im a big fan of the ceramic hybrids. i use hydrosilex.
it reduces the few steps involved in applying the wax.
immediately after washing the car ( while the car is still wet) i apply the ceramic wax spray.
using the shammy i wipe it off. afterwards with the same shammy i use it on the interior.
1 - 6 of 6 Posts
