1 - 2 of 2 Posts
It's conventional to flush the brake fluid (at least to avoid wasting fluid) by starting as far away from the master cylinder as possible and working your way closer (rear passenger-side first, then rear driver, front passenger, and finally the front driver). BUT! This may not be the case when the ABS system is in the rear, which I hear is true of 2012+ Honda CR-V's. Honda recommends a very different sequence for Gen4 CR-V's: front driver, front passenger, rear passenger, rear driver.
So does the 2016 Honda HR-V have the ABS in the back? What's the best order to flush the brake fluid?
Also, how much fluid is needed for a full flush? Honda Dot 3 fluid seems to be most often sold in 12 oz bottles (and 32 oz. is harder to find), but on some cars you need all 32 oz... does this mean I should buy three 12 oz bottles?
IMO if you are simply flushing (not replacing components) you can start at any wheel. I start at the farthest (and yes, we have CR-Vs as well).
I use low moisture absorbing NAPA brand DOT4 brake fluid, I believe it is Castrol. It is available in both 12 and 30 oz. bottles. It has taken me ~25 oz or so to do our cars. (I alway pour a little BF in a glass jar at first,so that I can better compare the color. Such is the consequence of doing BF changes ON TIME, LOL.
Reactions: brozog
1 - 2 of 2 Posts
