Excuse me, I have a 2017 Honda HRV EX FWD, and the ride comfort has never been good. I know that coilovers are mainly for lowering the car, but does yellow racing actually improve your ride comfort?I love these coilovers. They make the car look more like a hatch than a CUV. View attachment 31224 View attachment 31225 View attachment 31226
It makes the ride bumpier but im sacrificing ride quality for looks and handling. It also depends on the dampening setting that you set it at for the coilovers.Excuse me, I have a 2017 Honda HRV EX FWD, and the ride comfort has never been good. I know that coilovers are mainly for lowering the car, but does yellow racing actually improve your ride comfort?
I dont think it will work with the CVT trans unfortunately.So you have an AEM aftermarket air intake, modded exhaust system, modded suspension, wheels and tires.
The next item to consider is an under-drive crank pulley.
2006 - 2016 Honda Civic R18 Pulley Kit NST21915K
Need Civic R18 Pulleys? We've dedicated 15+ years to perfecting THE Best Lightweight Pulleys you can buy & we SHIP them Free Of Charge & Fast AF!www.nonstoptuning.co
It looks like NST used to make an underdrive crank pulley for the 1.8L engine but no longer.
I poked around on a Honda Civic forum about these pulleys but that was futile.
I have an underdrive crank pulley on our TSX and my 5.0L Mustang. It can really free up the engine with a manual trans, likely not nearly as noticeable on an auto trans engine.
In my experience a stock diameter, lightweight crank pulley makes zero difference because the radius is so small.
Under-driving the accessories has the most effect.
They are easy to install, not expensive (you will need a shorter serpentine belt).
I will keep trying to find one, perhaps I will email NST.
Looks great Wai Lam!
I still recommend to de-badge the rear hatch. All those badges look cluttered.
Let the sun shine on the rear hatch, fishing line to remove them, mild solvent to clean up residue and then wax the hatch.
That thing will run circles around the HRV's with the off-road type tires and stance!
Much more my style. Our 3 other vehicles are also lowered.
How did the wheel alignment go?
I'm still searching for an underdrive crank pulley. I did email NST. Zero success.
I would have no problems trying one on our HRV.
An underdrive crank pulley is more beneficial with a manual trans but would help with a CVT trans also.
Also for my rear coulovers, the left is somehow lower than the right slightly even thought they were both set to the lowestLooks great Wai Lam!
On a flat surface, measure all 4 corners of your HRV. Top of the wheel well, straight down to the ground thru the middle of the wheel center cap.Also for my rear coulovers, the left is somehow lower than the right slightly even thought they were both set to the lowest
The HRV does not have a power steering pulley (the civics do) - so that s another thing to consider - if the pulley/belt will still function.I dont think it will work with the CVT trans unfortunately.
