Hello everyone. I have a Honda HR-V 2018 with 120,000 Km (75,000 Miles) on it. I have changed the transmission oil at: 63,000 Km (39,000 Miles) and 100,000 Km (62,000 Miles). Every time I change the transmission fluid, I passed it through a fine filter and nothing was found and magnetic plug was clean I did the SB at around 65,000 Km (40,000 Miles). I am dead worried about this transmission failure. I am planning to keep this car as much as it runs with the goal of having at least 240,000 Km (150,000 Miles), approximately another 7 years. I have done all maintenances well ahead of the recommended intervals. Now I am worried if all these were done in vain! I don't mind changing the transmission fluid even at 20,000 Km (12,500 Miles) interval which means yearly for me. Do you think that the SB really helps? searching online, it seems that majority of failures are for 2016 model with some more on 2017 and 2018. What do you suggest?
IMO, with no warranty on your HRV CVT, you are justified in being worried.
IMO, every HRV owner with a CVT should be prepared for a CVT failure, both emotionally and financially!
Just like every Subaru, Nissan, Toyota and others with a CVT.
I was worried when we had our 2016 HRV CVT, enough to change the fluid way more than anyone else on this forum.
Even if you can swap in a good used CVT yourself in your garage, saving a ton of money, that would be no fun, plus downtime.
BY "SB", I assume you mean "TSB".
Going by this forum, I do think the CVT TSB (ECU s/w update) helped.
However as the 2016+ HRV"s get older with more miles on them, the reported failure rate seems to be increasing.
If you do keep your HRV, I do recommend to increase the CVT fluid change frequency.
It doesn't guarantee anything but it may help and it's easy and cheap.
We are sort of shopping for a replacement HRV, but I won't buy one without some kind of CVT warranty.
I would prefer to buy a 6 speed manual HRV, but no way to find one of these in my area.
Here are more of my thoughts on HRV CVT warranty:
