I'm looking for some used rims for next winter's snow tires and wondering if the wheels off any other Honda models fit the HRV.
Those are nice wheels and at a good price. I like that they look OEM. Did you get them in 16 or 17"?I found the Canadian tire sizing section insufficient, so I confirmed the rim/size I wanted elsewhere, then ordered the rim through Canadian tire.
Canadian tire does price matching, so they cost just over 100 each.
I highly recommend some winter alloys like the ones I bought here.
http://www.hrvforum.com/forum/401-tires-wheels-suspension/1561-honda-hrv-winter-tires-5.html
http://www.rtxwheels.com/en/wheels/rtxwheels-hyogo-silver
http://www.emwholesaleautoaccessories.ca/SearchResults.asp?Search=hyogo&Search.x=0&Search.y=0
When you minus size, you drop an inch off the rim diameter, but then replace that with a taller tire, to keep the outside diameter the same. This ensures your odometer, speedometer, and clearance stay the same.But how does the 16 help in the snow? You lose an inch of clearance. I would think the smaller diameter would make the car more likely to hang up in deeper snow.
http://www.tirerack.com/snow/Compar...mpareList=2,12&compare=true&sortHighLow=lowToHigh&displayResults=50&sortValue=1I have a set of 225 R16 snow tires from my old car that are in mint condition. I wonder how bad that would be to throw on the HR-V. Seems like a big difference in size to me...
You save twice with downsizing, cheaper rims plus cheaper tires.I got especially convinced when I discovered that the 16" Nokian tires are $40 less a tire than the 17" ones.
Maybe worth it even though they're nearly twice the price of the steelies.
Did you have to order bulge lugnuts for the wheels?
Thanks again.
Richard
Wheel was just delivered. "New condition" exactly as described, including the "H" logo cap in the center of the wheel. Beautiful packaging, with a black cloth cover stretched across the face of the wheel and closed-cell foam all around the rim. I had a moment of trepidation when I saw a "Black Widow" label on the outside of the box. This is a reputable source on eBay.Not "other" but there is a listing on eBay for brand new (dealer takeoffs) wheels for $130 each (plus shipping).
Thanks for the good reading material! My snows were actually 205/60-R16. Doing the calculator at http://www.miata.net/cgi-bin/tirescgi I don't think they would be a good fit. Site's I've read recommend .5% difference or less, some say 1%. 2.4% seems like a lot.http://www.tirerack.com/snow/Compar...mpareList=2,12&compare=true&sortHighLow=lowToHigh&displayResults=50&sortValue=1
Tire rack recommends downsized
or
So if your tires are 60R, should be good on the right 16 inch rims.
Specification Sidewall Radius Diameter Circumference Revs/Mile Difference
215/55-17 4.7in 13.2in 26.3in 82.7in 767 0.0%
205/60-16 4.8in 12.8in 25.7in 80.7in 785 -2.4%
http://www.miata.net/garage/tirecalc.html says....Hi. I recently purchases my 2016 Honda HRV, which comes with P215/55R17 tires, 7.5Jx17 ET55 rims and 5x 114.3 bolt pattern. I have a used set of Mazda 5 2008 rims+wheels, which are P205/50R17 wheels, 6.5Jx17 ET52.5 rims and 5x114.3 bolt pattern. Will they be compatible?
205/50-17 4.0in 12.5in 25.1in 78.8in 804 -4.7%
The wheels might work but the tires are way too small.Hi. I recently purchases my 2016 Honda HRV, which comes with P215/55R17 tires, 7.5Jx17 ET55 rims and 5x 114.3 bolt pattern. I have a used set of Mazda 5 2008 rims+wheels, which are P205/50R17 wheels, 6.5Jx17 ET52.5 rims and 5x114.3 bolt pattern. Will they be compatible?
Yes, that will work. Just make sure that the center bore is 64.1 mm or bigger. If bigger, I'd recommend hubcentric rings for a snug fit.Would 18 x7.5 with a 48 offset work?
