That's a very helpful (as well as alarming) article. For a technology like this, I would expect the vulnerability to exist for all models from a given manufacturer, but the article doesn't make it clear if they tested all or only some models.
Given the distances involved "
one is meant to be held a few feet from the victim’s car, while the other is placed near the victim’s key fob," I'm surprised that this is more than a theoretical issue, as reported by journalist Nick Bilton. From his description, his kitchen must be
very close to the street or sidewalk.
Last year I carefully measured the distance at which the keyless fob stops working at exactly 5 feet. Add just one more inch, and it stopped working. Our house sits back ~80 feet from the curb, and the car is inside a garage, so I'm not going to lose any sleep over this, but I can see where it would be a concern for someone in a denser urban environment, and when travelling and staying in a motel, I might consider putting the fob in a mini fridge or, if the room has one, a safe.
I just did some experiments:
— Bigelow tea canister: driver side attenuated to ~2 feet; passenger side <1 foot
— Lead lined film pouch (left over my silver film photography days: about the same as the tea canister
— 12" cookie tin: < 1 foot driver side; unusable passenger side
— Aluminum water bottle: unusable from closed end, about same as the cookie tin from the (plastic) stopper end
— Stainless steel thermos with plastic-lined metal cap: same as aluminum water bottle
— Stainless steel thermos with 3 layers aluminum foil under plastic-lined metal cap: unusable at any distance
— All steel, double walled coffee press: unusable at any distance
You can also buy a
Fob Guard for $30 — probably the most effective solution (if you feel at risk), as even if you get out of the car, and an accomplice walks right by, the fob is always shielded.
Putting the fob in a refrigerator or freezer is a bad idea, since rapid temperature changes are bad for electronics.
