Official Honda of Japan photos.
Should be the 2023 models according to our dealership.
Looking good, hopefully NA will get soon
Urban Cycle (mpg) | 91.1 mpg |
I don’t know the algorithm they use? PHEV will use gas if the engine has not been used for awhile. You don’t want the same gas in your tank for months.The HRV hybrid will be nice. My son is getting a new car and is pretty set on the Toyota Rav 4 prime. He drives every day under 50 km, so he may not need to buy gas unless he goes on a trip. 42mile/68km Electic only range
I think this is a really smart way, tiny battery that can do short drives daily electric only.
Why drive daily with 1,000 lbs of batteries for an 8 hour drive if you don’t need it
I hadn't realized this was an issue.I don’t know the algorithm they use? PHEV will use gas if the engine has not been used for awhile. You don’t want the same gas in your tank for months.
That's uh... new problem. I mean, what if you don't actually use any gas, there's a limit to how much you can add to a nearly full tank. So, does that mean you HAVE to make sure you use gas in some fashion? Like stop charging at home and make sure the drives use the gas engine?The RAV4 Prime’s driver’s manual states “fuel may remain in the tank for a long time and undergo changes in quality depending on how the vehicle is used.”
Toyota recommends adding at least 20 litres of gasoline every 12 months. If fresh gasoline hasn’t been added in a while, the main display will flash a message telling you to add fuel.
Toyota said stale gasoline isn’t usually an issue in regular hybrids, such as the Prius or RAV4 Hybrid, because they can only be driven in EV-only modes for short distances – sometimes for less than a block.
